S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1994 S500 Door Close Assist Only Working On Driver's Door and Trunk
Old Nov 28, 2012 | 11:41 PM
number_one_c55's Avatar
2017 G63
Question 1994 S500 Door Close Assist Only Working On Driver's Door and Trunk
Just bought a 94 S500 and trying to fix the little things on it. I noticed the only two doors that the self close assist works on is the drivers door and the trunk. Does anyone know of a trick to get the rest of them working? I can hear the pump run when I close the drivers door then shuts off only a few seconds after which I believe is normal.
Old Nov 29, 2012 | 02:44 PM
oldsinner111's Avatar
s320
yu can pull its fuse and reset thepump,it might fix it.Or its time to replace pump.
Search V12 Uber allies find the sight in thre is a complete wrie up on how to repair pump.
Old Dec 8, 2012 | 08:03 PM
eddie a's Avatar
94 S420,95 S500 ,96 S500
Take the pump out of the trunk, open it up and there is a micro switch inside you can adjust and this might fix it.. oldsinner mentioned the website to look at, very informative..
