S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Another duovalve question
Old Jan 22, 2013 | 03:40 PM
Rod Spohn's Avatar
2011 E350 Bluetec, 1996 S320 & 2006 E320 CDI Sold to my son & 2017 GMC 2500 Diesel Pick up
OK following several posts I took apart the duovalve, it was kind of gunked up so hoped that was the problem. I cleaned & lubed it but still nothing. SO how do I test the little pump to know if thats the problem. The hoses going in are hot the out are cold so I'm sure it's just not working but need a test procedure if anyone has any ideas. Thanks
Old Jan 23, 2013 | 07:13 PM
eddie a's Avatar
94 S420,95 S500 ,96 S500
Theres two plungers in side that get stuck, you can test the pump by taking it off and apply 12 volts to the posts..I think they are marked positive and negitive
