S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1995 S600 sedan - how to remove cover below instrument panel??
Old Feb 21, 2013 | 05:53 PM
mfr3's Avatar
'95 S600, '77 300D
greetings!
my car: 1995 S600 sedan
my problem: i need advice removing the drivers side cover (see photo - cream carpeted cover) located below the instrument panel/steering wheel. i am trying to remove the Steering Angle Sensor (N49) and therefore need access to associated connector N49/X1, located under the instrument panel/steering wheel.
i am following the WIS procedures removing all visible fasteners but still having problems releasing the forward edge of the subject cover (see photo - cream carpeted cover).
i read somewhere there are two spring loaded retaining hooks that keep the lower dash in place and to run a magnet over those two areas, fiddle around with a screw driver and that would disengage the hooks. no luck! i even peeled back some of the carpet edge on the cover to see if any fasteners were hiding.
the reason i am troubleshooting the Steering Angle Sensor (N49) is because of DTC fault 015 which i am able to clear, and fault 017 which does not clear even after initializing the Steering Angle Sensor (N49) by turning the steering wheel all the way right/left. i am reading these DTC error codes from the diagnostic connector pin-11 (ADS).
thanks very much to the benzworld.org community!
cheers,
rick
'73 280E
'90 260E
'77 300D
'93 300E
'95 S600
Attached Thumbnails 1995 S600 sedan - how to remove cover below instrument panel??-s600-cover-2.jpg
Old Feb 21, 2013 | 07:09 PM
mfr3's Avatar
'95 S600, '77 300D
Originally Posted by mfr3
greetings!
cheers,
rick
'73 280E
'90 260E
'77 300D
'93 300E
'95 S600
got it at end of this video:
never would have figured it out. WIS says to remove 2 screws when in fact 2 hooks/latches need to be released instead - well hidden by the way.
Old Apr 29, 2013 | 01:33 AM
oldsinner111's Avatar
s320
this is a old post but I'll answer for ease. start by removing mat.Pull on the right side down,it will reveal screws. with door open pop the rounded triangle out,theres a screw.On the floor theres a screw which holds.near parking brake handle pull down I think one more then black part neer panel two more unplug data line,its out
Old May 2, 2013 | 06:11 AM
eddie a's Avatar
94 S420,95 S500 ,96 S500
greetings!
cheers,
rick
'73 280E
'90 260E
'77 300D
'93 300E
'95 S600
There are two clasps that hold it on. They are located on each side of the steering column. Ill try and find the pictures I have to show you location. You will need a small screw driver to un latch each of them and the rest are phillips head screws. They are two latches that unhook with a small lever. I cant find the pictures I had. Email me at alberini69@hotmail and Ill take pics of a parts car, if you still need advice.
Old May 17, 2013 | 09:05 AM
ArizonaWhite's Avatar
S320
Here are some pics of the latches that release the panel.
Attached Thumbnails 1995 S600 sedan - how to remove cover below instrument panel??-user299467_pic8251_1367445935.jpg   1995 S600 sedan - how to remove cover below instrument panel??-user299467_pic8249_1367445935.jpg
