S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
'Gotchas' in changing plugs on a 95 S320?
Old Apr 9, 2013 | 10:48 AM
Gummee's Avatar
95 S320, 1960 190SL (waiting)
So its spring and time for maintenance, right? Since I don't know when the last time plugs were changed, I decided to do something easy.
...except things are worse now than when I started!
The spark plug cover fought me coming off. 3 of 6 bolts were so tight, it took muscle to get em loose. (I'm pretty sure those 3 holes are now stripped. Yes, I was loosening, not tightening them!)
The spark plugs themselves fought me coming out. It was like someone put em in with an air wrench!
So I get things buttoned back up except the cover won't tighten and now the car feels like its running on 4 of 6 cylinders. Plugs are snug plus an eighth of a turn, not 'air wrenched' on.
Is the cover bolting down the coils *that* important to the well-being of the car?
I don't *think* I messed up the wires to/from the coils when I pulled things. Nothing felt 'off.'
I didn't disconnect either sensor on the crossover tube, I loosened the hose clamps closest to the crossover and just removed it, leaving it connected to the wire/sensor on the driver's side of the engine
...so what went wrong?
Better question: how do I undo my goof?
:ear
I'm pretty sure the car is in 'limp home' mode. I haven't searched yet, but can someone point me to the thread that tells how to re-set that? ...or does the car do it on its own?
M
(how's that for a first thread?)
Old Apr 9, 2013 | 06:11 PM
Gummee's Avatar
No one?
M
Old Apr 18, 2013 | 05:30 PM
Gummee's Avatar
Did some diagnosing: One of the coils wasn't firing. Figured it out as I was checking spark plugs. Swapped coils 1 and 3 and the car ran like new(ish) till yesterday when it started acting up again.
I'm not sure if it isn't the engine wiring harness + old coils or just old coils. No, I haven't done the engine wiring harness yet. I'm pretty sure it needs it on top of a bunch of other 'deferred maintenance' from when it sat after Dad passed away.
M
