Cruise control and some are not working
w124 and w140
W140 S320 M104 there are some function completely not working such as
Cruise control, Fuel consumtion display, Speedometer and also Trip recorder, Odometer ( still dissplay but not add up or count ). and warning
lamps of ETS fault , ABS fault are lights up.
The other Function in Instrument cluster are OK.
So please advise where or which area that need to checked
thank you for your help !
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
First recheck and make sure that your battery is providing at least 11v. Second get a quick scan that will isolate all the IC faults. Third,cruise, assuming battery is providing the voltage, test or replace the brake light switch.
