S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1997 S320 A/C Blowing Hot
Old Aug 7, 2013 | 09:47 PM
jamesodom's Avatar
1997 mercades S320
Question 1997 S320 A/C Blowing Hot
I have a 1997 S320 that I changed the Water pump and some other items on the engine and now the A/C Blows hot.
This did not do this before the water pump went bad.
I have checked the A/C compressor and it is working and has the correct Freon in it.
I believe there is a problem with a vacuum causing the blend door to stay on hot.
I have checked the Vacuum line that runs from inside to the intake and it is good. I find no vacuum leaks anywhere.
My repair book shows very limited pictures on this issue
any help would be great.
