S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
A/C Issues
Old Sep 15, 2003 | 08:39 AM
solhood's Avatar
1994 Mercedes Benz S 500
A/C Issues
I am having some difficulty with my 94 S 500 A/C. When the engine is on and you open the hood you can hear the a/c motor running. There are two wires (red and blue) that run into thte a/c area. When I barely touch these wires the a/c starts blowing without a problem. All lights on the dash work and you can even feel the a/c trying to blow inside the car. All it takes is a little touching of the wires for it to stop. Doing this however is time consuming because it goes out almost every time after you turn off the car. Thanks.
Old Sep 15, 2003 | 07:04 PM
ghost's Avatar
1997 S600 - Bentley Turbo R (black/black)
check if these wires are connected properly..there might be a loose connection somewhere...
