S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Secondary vacuum
Old Nov 27, 2013 | 06:19 PM
Gdsmith07's Avatar
1996 s420
Secondary vacuum
None of my shut assist works and it's throwing a code for the secondary vacuum just wondering what the problem could be and where the fuses and such are located so I can start going through it my names Greg thank you
Old Dec 14, 2013 | 08:16 AM
oldsinner111's Avatar
s320
you have a fuse panel in trunk,pull fuse for locks to reset,hopefully this will fix your problem.If not the vacumm box is under your rear seat on the right.
