S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Cylinder Misfire
Old Nov 15, 2003 | 04:46 PM
///S320's Avatar
S320W
Cylinder Misfire
I went to auto zone to get my check engine light checked. The code reader said:
Cylinder misfire on cylinder 1 and 4
Random misfire
Does anyone know what misfire means? what kind of a problem iam looking at and how much would it cost?
Old Nov 17, 2003 | 11:10 AM
Jer's Avatar
Jer
1994 E320
"Misfire" is a condition in which the combustion process does not occur as it should. It could be caused my a number of reasons. Fouled spark plugs will not deliver a spark and the fuel/air mixture will not ignite. The ignition timing may also be too early (advanced) or too late (retarded). I wouldn't do much driving with such a condition because, depending on the cause of the problem, you could flood the affected cylinders. Check the spark plugs first.
