S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
qestion about my 96 s500
Old Jan 18, 2014 | 10:19 AM
Blue S500's Avatar
S 500
my trunk button dose not pop my trunk an my trunk assist dose not come out, what do i do?
Old Jan 26, 2014 | 09:26 AM
1999 S500's Avatar
1999 S500 Grand Edition
Trunk release, door locks, doors and/or rear deck doesn't close all the way, are all common problems on the W140.
Does the trunk release when you pop the button on your console above the shifter?
If it opens:
Step one: Reset the fuse in the trunk. I believe that it is #9. Pull it out and put it back in.
If that doesn't work:
Step Two: Start at the PSE pump under the back seat and go from there. A leak anywhere in the system can cause the other parts to not work correctly. There is a secondary pump in the trunk for the latch and trunk release. Check that one out as well.
Mine had a leak in the hose connecting to the passenger front seat adjustable lumbar support that was causing the AC vents to open and close erratically. Capping it off seems to have curred the AC problem.
I replaced one of the acutators in a door and it caused the other 3 weaker ones to break. Lots of weakest link theory going on in that system.
I have a 1999 S500 so to me, this is the most annoying system in a W140. ( no wiring harness issues on later W140s) Even when it is fixed, you still have to reset the fuse now and again.
Good Luck,
Mark
Old Feb 2, 2014 | 12:52 PM
Blue S500's Avatar
S 500
If it opens:
Good Luck,
Mark
no my trunk button dose not work. my door locks are not automatic at the moment either.
Old Feb 4, 2014 | 09:19 AM
oldsinner111's Avatar
s320
my door locks work but trunk is kaput.I think the hoses to trunk actuator are broken
