S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
loss of full throttle
Old Feb 4, 2014 | 09:51 AM
oldsinner111's Avatar
s320
I have had a problem with my car since June.Engine would only accept 1/3 pedal.Anything over it would cough and buck.I spent over $600 in parts cause it failed to show a code.New coils,wires,plugs,oxygen sensor,fuel pump,filter ,MAF,and drained fuel tank.Last night I got hold of a Snap On Tools diagnostic scanner,and I ran a Throttle Position Senor check.No voltage after 1/3 throttle.
So if you engine ever feels like its flooding and not taking off.Check the TPS before you do anything.
Old Mar 24, 2014 | 02:58 PM
s320
not TPS it was the crank sensor wire not fully plugged in.
Old Mar 29, 2014 | 06:58 PM
1999 S500's Avatar
1999 S500 Grand Edition
Thanks for the heads up!
Old May 5, 2014 | 07:18 PM
cool_lagoon's Avatar
(1960) 300d, S550 AMG S500 S600 560SEL
oldsinner do you have a picture of the crank sensor plug and its location?
Old May 6, 2014 | 06:40 AM
s320
cool on my engine its right above the starter.Road debris knocked mine loose.
Old May 6, 2014 | 09:13 AM
do you have a picture? would you kindly post it. was wondering what is the relationship of crank sensor with the hesitation of your engine to run properly. by the way what is your model and series?
Old May 6, 2014 | 11:35 AM
s320
I have the inline 6 cylinder m104.I got my information to remove it from the Peachparts forum.FromPelican parts.
Old May 6, 2014 | 02:23 PM
which part of the peach part forum did you get your info?
Old May 7, 2014 | 06:03 AM
s320
I got the information from there sponser Pelican Parts.Under the 210 model
