S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Fixing diagnostic faults (how?)
Old Nov 21, 2003 | 03:18 AM
amgmercedes's Avatar
My 93 E420 has the following indicated faults which I found out using the diagnostic LED:
6 blinks: idle speed control inoperative.
Is there a part I should replace here? My idle sometimes fluctuates slightly, but most of the time its fine.
25 blinks: Knock sensor
Where is the knock sensor located? How do I know if I should already replace it?
26 blinks: upshift delay switch over valve (SOV) open/shorted
What does this mean?
Thanks.
