S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Strutmasters S500 Conversion Set
Old Feb 28, 2014 | 08:54 PM
1999 S500's Avatar
1999 S500 Grand Edition
Anyone ever done this?
1991-1999 Mercedes Benz S CLASS W140 Chassis Models With RWD Rear Hydraulic Suspension Conversion Kit
Replace Your Hydraulic Suspension And Save Up To 75% Compared To The Cost Of A Typical Repair!
Our conversion kits are designed to be direct replacements for your vehicle's hydraulic suspension. They require no modification to your vehicle and are designed to "bolt on" without any welding or cutting.
Installing one of our kits is easy. If you can do a brake job, you can install this kit. Strutmasters can also help you find a local mechanic if you need one to do the installation for you.
$495.00
Mercedes wants to hit me up for $2800 to replace my rear hydraulic struts. Then I would imagine that I will get to fix the pump and hoses next. This conversion set seems to good to be true.........................
Old Mar 9, 2014 | 03:42 PM
N2finances's Avatar
1995 s500 coupe mercedes benz
Rear hydraulic suspension conversion kit
Can you send me contact info for Strutmaster and if possible part# for kit Thank you
Old Mar 9, 2014 | 04:10 PM
1999 S500's Avatar
Here is the link,
http://www.strutmasters.com/Mercedes...it-p/mw1rb.htm
I saw in the W220 thread that some other people are doing this with good results. My S420 came with normal spring/shocks and its ride was great so I think I will be doing this.
