S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
problem with torque converter (1997), need help!
Old Apr 20, 2014 | 08:30 AM
chopiz's Avatar
S600
Red face problem with torque converter (1997), need help!
Hello every one
glade to be here among you
so Star diagnostic showed that my car has a fault# 053 torque converter
lock-up clutch (KUB), high power consumption!
and i asked them about it and they said i need the change the TC in-order
to solve this problem, my car is about 135K and its 97 S600
i have owned the car since it had 98K in the odometer and have not noticed
any problem form the gear except one or two in a new day when using the car for
the first time the gear i drive mode stuck for about one minute in first gear
while the RPM would reach 2 and exceed it i don't know if this is normal to the w140!?
the second note is when turning the car to the right i usually left-off the
gas pedal but after the turn in a slowing speed with out touching the breaks
when hitting the gas there is a big knock from underneath the gear which is
noticeable form inside and ohhh i forgot there is a Third note the same knock
before is there when using the kick down for the first time in a day!
are those enough indications that tells me that i do need to change the TC
ASAP or its fine now and can hold for like +30k until the next gear service
because the time have come to do the 135K service.
Old Apr 20, 2014 | 09:51 AM
oldsinner111's Avatar
s320
I have never heard of a TC being replaced.What I have heard is the wiring plug can leak into computer,the plate going bad,debris unhooking wires,and antifreeze leaking into fluid.
Old Apr 21, 2014 | 03:21 PM
chopiz's Avatar
S600
the computer scanner showed there is a problem with the torque converter
other wise it would say another fault since the car is full of sensors every
where but thanks for the replay.
still waiting
