S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
How to mix coolant
Old Jun 8, 2014 | 06:08 PM
c140benz's Avatar
c140
How to mix coolant
Dear gents , recently I replaced the old radiator with new one the mechanic added a gallon of mb coolant and the rest was a drinking sealed bottels of water, was it right?
Old Jun 9, 2014 | 10:59 AM
pncurtis's Avatar
1997 Mercedes S420
The answer to your question really depends on which brand of bottled drinking water was used. My preference is for zero water which is filtered to remove calcium and sodium, the two things that will cause internal failing of a cooling system.
You may also consider dionized water and distilled water as alternatives.
Old Jun 10, 2014 | 05:48 AM
c140benz's Avatar
c140
so in enviroment that the temp reaches 48c how do i mix the coolant should i do 50/50 or 30/70?
Old Jun 10, 2014 | 09:55 PM
JonMBZ's Avatar
06 C55, 09 E350
http://www.gani.com/public/benz/antifreeze-back.jpg
Old Jun 11, 2014 | 04:56 PM
mtahiri's Avatar
cl500 1996
Thanks, I will do my best.
Old Jun 13, 2014 | 04:47 PM
ECSTuning's Avatar
Former Vendor of MBWorld
2012 SLS AMG
Everyone,
I just want to post this to help out others that may be looking for information on MB coolant and cooling systems.
First, it is recommended that the cooling system be flushed every two to three years, using only genuine Mercedes-Benz coolant or Zerex G-05 coolant. These are the only two coolants that are approved for use in these cars.
Second, coolant should only be mixed with distilled water so that minerals are not introduced into the system, which could lead to internal corrosion.
If you are looking for the correct coolant for your car, we offer it on our website. You can get to it by clicking HERE, or by clicking on the photo of the coolant below.
If you are changing the coolant in your car, we offer this Coolant Evacuation Tool Kit so that you can re-fill your cooling system without air lock issues.
You can find the Coolant Evacuation Tool Kit on our site HERE, or by clicking on the photo of the kit below.
If there is anything else I can help out with, please feel free to post or send a PM!
