S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
help with coupe windows
Old Dec 21, 2003 | 06:21 AM
guydewdney's Avatar
anyone got a wiring diagram for the window system on a coupe? the back left doesnt drop as the door is opened. tried re-setting (pulling fuse etc) and can get the right window working correctly, but not the left.
it auto downs on second click
front window drops when the door is opened (so the door switch is OK)
any ideas?
Guy
Old Dec 22, 2003 | 02:55 PM
guydewdney's Avatar
ah - fixed it.
turned out the motor had been taken off, and so it had lost its posistion. take motor off, press down on switch - it stops after a moment.
press down again, it keeps spinning.
reset
all works again.
