S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
anti freeze flush
Old Dec 25, 2003 | 03:03 PM
s_nik's Avatar
93 500 SEL, 92 MR2, 90 Eclipse
anti freeze flush
hey everyone,.. merry x-mas
I like to flush the antifreeze in the car (S500). I know the capacity is 16.5L, and best ratio for me would be 60 water/40 antifreeze, so that would be 6.6L of pure antifreeze and rest would be distilled water
If I open the rad drain plug only a small % of existing coolant will drain which bring me to this:
where exactly is the coolant drain plug for the block? how do I make sure all of my coolant is drained? I also want to stick a garden hose in there and flush all the residue out... is it best if i remove the thrmostat so water can circulate the cooling system freely?
last but not least, once its all topped up, how do I bleed the cooling system?
anyone done it? I need details
