S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Engine stumbles when cold
Old Dec 26, 2003 | 11:05 PM
amgmercedes's Avatar
My S600L's engine stumbles and sometimes dies when you start it from cold. You have to give it some gas before it will idle smoothly.
There is no problem when starting with the engine warm.
Any ideas?
Thanks.
Old Dec 27, 2003 | 09:06 PM
MB AMG's Avatar
2002 E55 AMG
Does the engine shake when you first start it up?
Old Dec 28, 2003 | 01:46 AM
Bernanke's Avatar
Try this. At next oil change, change the oil filter and drop in Mobile one 5w - 30 fully synthetic. That oil is like the rolls royce of oil. Motor will run much smooother than on that dyno sludge you have in there. The synthetic not only runs smoother, provides less resistance and helps motor rev better, its also flow much better at room temperature and instantly starts lubricating the engine vitals right on startup, dyno oil takes a while and is like molassis at room temperature.
hope that helps.
Old Dec 28, 2003 | 10:38 PM
Shake? well not really. Just a bit more vibration since its not running smoothly when cold.
About the synthectic oil, thanks for the info and maybe I may try them on my next oil change. But I dont think that its the cause of the problem since Im in a tropical country and the oil never gets to see cold temps.
Old Dec 29, 2003 | 12:03 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
careful about using syn oil in older cars...not sure what year your S600 is, but with syn, it is thinner, therefore in older engines, it can lead to leaks in places where the dyno oil wouldn't.
just my .02
-G-
Old Dec 29, 2003 | 01:13 AM
Bernanke's Avatar
Thats not necessarily true, at running temperatures it has the same thickness as a dyno 5w-30 oil but when cold (i'm not saying freezing, even at room temp or a few 100-200 degrees) its alot "thinner" you could say but that allows all the vital engine components to get instant lubrications.
If cold running is the problem its most probably oil. Give it a try if it doesn't work at least you are better protecting your motor and will have smoother revving car.
its a win win situation
Old Dec 29, 2003 | 02:26 PM
MB AMG's Avatar
2002 E55 AMG
I drive a 1992 600SEL. This is pretty common. I really don`t know what the dealer uses for oil. Mobil 1 in the newer MB engines, but not sure about the older? Had any mojor problems with the engine lately?
Old Dec 29, 2003 | 04:13 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
I'm guessing most dealers use either Castrol GTX for older cars and Mobil 1 syn for newer, 98+ when they introduced FSS I think.
I've been getting Castrol GTX every oil change...
-G-
Old Dec 29, 2003 | 06:15 PM
Mark Pedersen's Avatar
S600 Coupe. 560SEC, E55
We have a 93 600sl and a 95 s600 coupe. Use mobil one 15w50 in both and it seems to work well.
Old Dec 30, 2003 | 12:11 AM
Bernanke's Avatar
man 15W-50 thats some THICK STUFF hehe. I'll try 5-30 synthetic and see how that turns out. I have a 6 banger so i want it to be real peppy and rev like no other. i'll let yall know the results.
Old Jan 2, 2004 | 03:08 AM
Dual 5Ls's Avatar
94 Wagon, 13 ML63
I also use strictly Mobil1 15-50w in my cars and it runs better with it. I've noticed that the Mercedes likes to eat it up a little quick, but that is most likely an oil leak that originated before I bought the car. I recommend Mobil1 for any german engine.
