S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
lightswitch bulb replacement
Old Jan 11, 2004 | 02:44 PM
guydewdney's Avatar
admittedly i havent really looked, but how does one replace the small illumintion bulb behind the lights on / off / park switch (and I assume the headligh aim roller adjuster thing)
Old Jan 12, 2004 | 07:24 AM
Peter Guenther's Avatar
92 500sel/01 320e wag
140 ligtswitch bulb
Remove the knob by pushing a small screwdriver into the slot at the bottom of it, It should pull off. Next remove the screws that hold the parking brake handle trim. There are more screws at the top, look up you will see them, remove. Remove the nut on the light switch, the panel should pull out, the steering wheel switch can also be pulled forward. The bulb (miniature) is in a socket and pushed in to the light pipe.
Get the bulb from MB a (couple of bucks) beforehand they were out when I got mine. It turned out to be unplugged or fell out of the socket. It might be slightly different on the adjustable headlamp version.
Old Jan 12, 2004 | 08:13 AM
guydewdney's Avatar
thanks
just been out - very simple once you can see.
1) shove small flat screwdriver into lightswitch bottom and pull out
2) remove top screw above steering wheel adjuster, and pull out switch complete. noneed to unplug
3) remove two screws from behind steering wheel switch
4) remove two screws from under parking brake release handle
5) undo 20 mm ish nut (I used an adjustable) from lightswitch
6) pull assy out - with headlight aim switch it only has 1" movement - but this is enough to get at small 1.2 watt bulb. (white base)
(fog light warning bulb is 0.5 watt (grey / gray base) - not a direct swap over )
go buy a new bulb
Thanks again.
