S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Climate Control died
Old Mar 13, 2015 | 05:32 PM
1stw140's Avatar
s350d
Question Climate Control died
I have a 94 s350 w140 with climate control that will come on and work normally, but when I turn off the power and remove the key it stays powered up. the outside fan continues to run as does the inside fan, also both "AOTO Button" lights stay on. I have to unplug the control unit to power it off. One other thing,... if I plug the unit back up without turning the ignition the unit wont power up untill the key is turned on. Any help will be appreciate.
Old Mar 13, 2015 | 05:50 PM
Germancar1's Avatar
2013 650i Coupe, 2010 IS250 AWD, 1999 S500
Mine did the same thing a few times and then it finally went out. Now it works, but the fan speed will not increase at all. Old, fickle electronics. Mine did this after I ran the car up to about 120 mph one day. The fan was blowing gale force hard and then wouldn't shut off even after I cut the car off.
M
Old Mar 13, 2015 | 06:19 PM
1stw140's Avatar
s350d
Some suggested it could be a faulty relay not closing ? If so where is that sucker !!!
Old Mar 13, 2015 | 06:24 PM
Germancar1's Avatar
I'm not going to attempt it, I got a really good mechanic so when we get some really nice weather I'm going to drop it off for a look.
M
