My buttons sank in !!
I am not sure if this related to the very cold weather we had, or is it a spring issue, because the wood center console seemed to be aligned fine. The buttons are both for the rear windows and they are aligned below where they are supposed to be.. One still operates one window, the other is not.
Anyone experienced something like that, and how to fix it?
ghost
Also the switch for the windo in the right rear door actually fell out, leaving a hole. Had it fixed, Happend again. No one ever sits back there!
Have no idea how to fix it. I suppose removing the wood panel would reveal what holds it in place, or thinks it holds it in place.
Mine is a 1995 S420
2 of my buttons sank in, and they are for the rear windows, which i hardly use, thank god.
I managed to somewhat fix one of them, using a butter knife. I snuck it in the gap and wiggled it here and there and one of the buttons managed to rise up to almost the same level as the normal two. The last button, i tried for a while but it wouldnt come up to the same level. It does work though, which is good.
i am not sure if i want to take the ashtray and the wood pannel off and fuss with it, i am afraid i will do more harm then good. Basically my concern with the buttons are cosmetic rather then function.
$70 dollars for a button seems hefty, but its a benz...
I guess thats true what they say about benz dealer service, less organized and less friendly then your local lexus dealer service.
Thanks again
