S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
rough idle
Old Jun 8, 2015 | 07:21 AM
marketventures's Avatar
93 300 SE
rough idle
NEW INFO
my 1993 300 SE 81,000 miles.
At a stop light engine "stumbles" then smooth a second or 2 and stumbles again. This only happens after the car has been sitting a few days. I default to fuel filter but not sure.
Anybody else familiar with this?
Old Jun 8, 2015 | 08:14 PM
KNBS550's Avatar
Mercedes-Benz 2007 S550, 2012 S550 4-Matic, 2014 S550 (Traded), 2015 GL450
Could be a number of things. Get a code reader for about $100 or go to an auto repair shop that will read codes for you. My first instinct is an ignition coil, but you have to know which position it's in before replacing.
Old Jun 15, 2015 | 07:30 AM
burgca's Avatar
'97 S500 Coupe, 2016 AMG S63 Coupe, 2007 Audi Q7
I agree that the description could be a simple engine coil, or something else and it doesn't make sense to spend money on a part until you know what's wrong. A code scanner is a must if you have an older benz as you will get to use it more than you can imagine. Post your results and maybe the forum can help.
Good Luck!!
Old Jun 18, 2015 | 01:54 PM
oldsinner111's Avatar
s320
spark plugs are cheap,then coil or cap if you have one.Followed by spark plugs wires.
