S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
My 1996 S500 has had an electrical stroke
Old Nov 11, 2015 | 08:24 PM
OldNavy's Avatar
1996 S500
It is starting to seem like my 1996 S500 has had a stroke. It's just over 200k miles and otherwise is running alright. Here's what has happened: first, the cluster lights went out, then the right low beam head light died (but not the left or the high beam), then the cyclops brake light went out and the right rear parking light is out. So, it's not the bulbs; I've swapped them. I've replaced almost all the fuses, but none were tripped at all, either up front or in the trunk. After a while, the cluster lights came back of their own accord.
Perhaps it's unrelated, but I've been working on the antenna unit for a bit. I've been careful not to short anything and it works. I've also removed the CD playre in the trunk. I'm up for any wild ideas, or actually experience. Anyone want to take a guess? Thanks in advance.
Old Dec 13, 2015 | 08:54 AM
MacVidMB-V8's Avatar
W209, W124
Sounds like "Crispy Creme" wiring.
