S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
oil pressure
Old Aug 19, 2016 | 12:48 PM
beebsie's Avatar
2008 S550 4Matic and 2014 E350A Cabriolet
oil pressure
When driving, oil pressure is at " 3". When idling, it used to go down a little, now it goes down between "2" and "1". As long as it is "3" while driving, should I not worry?
Old Aug 19, 2016 | 04:36 PM
rcrc7's Avatar
1990 560 SEL , 1998 S 420
When there is an opportunity, do check out the oil tubes (16 pieces on M119)by removing the cylinder head covers. Personally, I dreaded to do this! But, it was a saving grace 'cos I found 2 pieces on the right banks 1 piece on the left banks were blown out on its ends. Could not find those "disc". Could be floating in the engine oil pan somewhere! ;-))
With engine running, open the engine oil refill cap, and I can see the oil sloughing around. That is my telltale that am in good shape! Spare you the details of me hooking up a pressure gauge to verify the PSI rather than the BAR. A bar equal to 14.5 psi. But still when the engine is hot, its normal to see the bar drops down... So, I guess, like every one says, ...as long as the gauge spring up to 3 bars while driving, we are good! ;-))
...hope this calm you down. ;-))
