S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Fuel filter question
Old Feb 17, 2017 | 10:38 PM
IgorE350's Avatar
01 ML55AMG 04 ML500 03 ML350 08 ML63AMG
Planning to do an fuel filter change, on my 1996 S320. Any help where its located and how to do it and all that. Maybe few pictures. Thanks
What else is a must to do to the car at 77k miles???
Old Feb 18, 2017 | 05:17 AM
oldsinner111's Avatar
s320
it behind right rear tire,may have plastic box cover,i would replace rubber lines too.may want to service transmission.
Old Feb 19, 2017 | 02:32 PM
IgorE350's Avatar
[QUOTE=oldsinner111;7059987]it behind right rear tire,may have plastic box cover,i would replace rubber lines too.may want to service transmission.[/QUOT
Ok, is it inside the trunk or outside under the fender? Yes i will do my transmission oil and filter change when it gets little more warmer. Thank you
Old Feb 19, 2017 | 03:32 PM
s320
under the car
Old Feb 19, 2017 | 03:35 PM
s320
i jacked my rear passenger side up, and slide under car and reached up to black box cover.remove cover everything is there.Can't remember in front,or behind axle
