S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Central Locking Pump Connectors
Old Mar 19, 2017 | 05:39 PM
pops76's Avatar
W140
Question...I was able to get a working central locking pump from a pick a part for a song but it has the updated connectors. Are these two way valves? Or could I take that top part of the new pump and connect my hoses directly to the corresponding fitting?
Thanks!
Old Mar 20, 2017 | 06:38 AM
pncurtis's Avatar
1997 Mercedes S420
If you have the correct pump for your particular vehicle the hose connectors should work properly without any alteration. However if the part numbers are not the same you may want to take your new pump back and get the correct one else things will not work properly.
