S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
97 S320 Drivers Front Window Jamed
Old Apr 7, 2017 | 03:49 PM
accesspro's Avatar
s320
Exclamation 97 S320 Drivers Front Window Jamed
Hello, I have tried searched and searched for a solution to the problem my 97 S320 is have with the drivers side front window. The window will only go down about 3 to 4 inches then stops, no problem going back up when switch is pressed.I have removed the window regulator and inspected but no obvious damage, the motor works fine also. i noticed the Clip on the left side but not sure how to adjust. Please advise. thank you
Old Apr 8, 2017 | 10:33 AM
DrDoe's Avatar
W212 E350; W166 GLC300; W164 ML550; W164 ML63; W221 S65; W220 S430; Escalade ESV
Did you just have some works on the window recently? I asked because my rear right window cracked. Safelite auto glass guy installed a new window and it behaved like yours because he placed it on a wrong setting. He said there's 2 different settings. Sorry but that's all I know about it.
Old Apr 13, 2017 | 07:44 AM
daddiojiggy's Avatar
'95 s500
reset window reg
