S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Will these tires fit 1999 S500?
Old Apr 10, 2017 | 01:56 PM
enthusednoob's Avatar
1999 S500
Factory size is 235/65/16, I found a set of nice looking Pirellis on craigslist for $100 but they are 235/70/16. I don't plan on getting new rims and obviously they're the same rim diameter, just not sure if that middle number makes them incompatible. Appreciate any insight, thanks.
Old Apr 11, 2017 | 07:33 PM
daddiojiggy's Avatar
'95 s500
the 'middle' number is the ratio or percentage that the side is of the tire width(1st number) ie. on a 200/50/16 the sidewall height is 50%(2nd #) of the 200(1st #). therefore in MY example the sidewall is 100mm. in your example the sidewall is 235X65% or 152.75mm. i think factory is 235X60% or 141mm.hope that helps.
Old May 15, 2017 | 11:02 PM
steelers6's Avatar
1996 Mercedes-Benz S420
They should definitely fit with no problem...
