S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Turn over delay
Old May 30, 2017 | 12:52 PM
Frank02261979's Avatar
2011 E550 Coupe, 2008 S550, 1997 S320, 1997 E320, 1985 300SDL, 1968 250S, 2003 Jaguar XJ8 VDP
Turn over delay
I have been having a slower turn over the last few weeks when starting the car (1997 S320). It starts just fine after running, but after sitting overnight, it takes a few to turn over (nothign major, just a few more cranks). I have new plugs, air filters, fuel filter, coil packs, etc...) any suggestions? I was thinking that the ignition cables may need replaced...
Old May 30, 2017 | 02:24 PM
oldsinner111's Avatar
s320
check your ground at bell housing and clean.I added extra ground from motor to chassis.How old is battery?I had one I had to open the top,and add water,2 cells were dry.
Old May 30, 2017 | 02:32 PM
Battery is a couple years old, but I will check that. this may sound dumb, but where is the bell housing?
Old May 30, 2017 | 03:01 PM
s320
where transmission connects to engine,you'l see a large cable
