S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Side vent air volume
Old May 3, 2004 | 06:07 PM
shmelvin's Avatar
none
My A/C blows cold out of the side vents but definately with less volume than the center (or rear) is this normal?
Old May 3, 2004 | 10:05 PM
JAM's Avatar
JAM
SL600
If all of your vent wheels are open, it sounds pretty normal. It's just part of how the climate control balances itself. On very hot days, you should get cold air out of the ceter as well. Also, the concept behind the W140's climate control is to move a large volume of air, but slowly as to minimize noise. Sometimes it may see that the flow is restricted, but from what I understand this is perfectly normal. Hope this helps.
