S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
engine vibration at idle, solution found
Old May 4, 2004 | 02:31 AM
Bernanke's Avatar
hey guys. for those of you with that annoying vibration at idle when you are in drive and on the brakes (at stoplight), I finally found out the problem. It was the motor mounts, so if you have the same problem just fix motor mounts and you will be ok.
Old May 6, 2004 | 04:44 PM
99bmw740il's Avatar
2006 Mercedes E350 Sport
Re: engine vibration at idle, solution found
was it a DIY or did you take it to a shop?
Old May 6, 2004 | 11:19 PM
Bernanke's Avatar
mercedes benz dealership diagnosed the problem
