S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1999 w140 dead battery seized trunk lock
Old Nov 13, 2017 | 11:26 AM
Sclass4me's Avatar
1999 S500 & 2000 S430
1999 w140 dead battery seized trunk lock, how do I open the trunk?
Old Dec 3, 2017 | 12:05 AM
300SDLguy's Avatar
04 CL & S600 designo Espresso's
It's been a while since I needed to do this, but you can remove the passenger side carpet panel and underneath you'll see electronics, I believe there is a metal panel you'll need to unscrew this panel to expose a large red Positive cable that will allow you to get power to your vehicle. Connect a positive side of a jumper cable or battery charger and the other to a ground post. This give you power to your car, and allow you to open the trunk. Also, I have found that using a product called Fluid Film worked wonderful in freeing up a stuck and corroded trunk lock in mine. Hope this helps!
