S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Rear Shocks
Old May 7, 2004 | 12:49 PM
rdanz's Avatar
Rear Shocks
94 S 500
How hard is it to replace the rear shocks?
Old May 7, 2004 | 02:56 PM
ANGMED's Avatar
S500 1997 + S600 2005
Had mine done a month ago, I watched them do it, not very easy for the nonprofessional. The connector line nozzle to the shock absorber, if damaged, would require half of the car to be dismantled in order to replace that hose coming from the reservoir to the shock absorber/wheel area, which runs inside the car, under the seats, etc etc. Not worth risking all that to save a couple of hunder dollars.
Old May 7, 2004 | 02:58 PM
ANGMED's Avatar
" a couple of hundred"
Old May 7, 2004 | 03:59 PM
Peter Guenther's Avatar
92 500sel/01 320e wag
Shocks
The 500 has a hydraulic suspension system, oil from an engine mounted pump is fed to accumulators which are gas filled diaphrams. These are linked to the hydraulic struts, typically the accumulators fail, the shocks fail late in life and are $450 ea. The accumulators are a $100 ea, signs are a rough or sometimes a bouncy ride with no signs of leakage. The accums are just messy since they are filled with oil under pressure, the struts are similar to shocks, take out the trunk liner the mountings are there.
Old Jun 6, 2004 | 12:11 PM
Michael Tubbs's Avatar
S500, benzo
rear shock accu------ors
and where can we find those, thanks in advance for the halp by the way.
