S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
center console rear a/c is not cold
Old Dec 29, 2017 | 10:49 AM
szulkarn's Avatar
R280 L
hi all. i own a 97 s320. the ac is working fine blowing cold air from the main front vents. but the rear center consoles vents are just blowing non ac cold air.
i turned the climate control wheel to hot or cold but its doesnt work. it just keeps on blowing regular non ac cold air.
does anybody ever experience this?
pls share. thank you.
Old Dec 30, 2017 | 05:40 AM
oldsinner111's Avatar
s320
if it has no fan controls its just a vent.
Old Jan 8, 2018 | 03:08 PM
vperalta's Avatar
1993 400 SEL , 2002 CL500
Szulkarn,
The rear vents through center console. If you have cold air coming through the from, it should just shoot out the back? I
don't think there is a separate condenser/compressor for the rear.
Old Jan 9, 2018 | 11:30 AM
s320
I have to tape mine shut in the winter,its plain outside air,under the front seats is ac and heat
