S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
S500 No ASR/ABS lights
Old Jan 17, 2018 | 09:18 PM
andyw124's Avatar
W124 E220 and C140 CL500
Hi Guys,
Hoping some one on here can help me as we seem to be drawing a blank,
When I start the car the ABS and ASR lights do not do there preflight checks/lighting up the don't come on at all. bulbs have been tested and are fine.
Car needs to have at least the ABD light do its thing to pass out local inspection (MOT) so hoping its quite a simple one!
Andy
Old Jan 18, 2018 | 08:01 PM
andyw124's Avatar
Hi Plutoe, thanks for the reply! I'm aware of the blink testers and was hoping to avoid having to make and use one to be honest, but if it works it works
Old Jan 24, 2018 | 04:53 AM
oldsinner111's Avatar
s320
could be bulbs they do go out,my state I removed all of them.
Old Jan 24, 2018 | 08:13 AM
andyw124's Avatar
hi do you mean the dash bulbs? I’m hoping to test them ASAP as the same symptoms have appeared out of nowhere on my other mercedes.
Old Jan 24, 2018 | 09:11 AM
s320
yes dash bulbs.But before make sure your batteries are ok,and have water over cells,and charging system is good.They can act strange with charging problems,I have had batteries with low water in cells.
Old Jan 24, 2018 | 09:35 AM
andyw124's Avatar
i actually put a new battery in the car last week as my old one died in storage and wouldn’t hold charge at all. Will check that the alt is gliding it’s job when I get a chance here.
