S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Vacuum pump
Old Mar 14, 2018 | 05:46 PM
Oren’s's Avatar
1998 w140 s320
Vacuum pump
Hey
i have w1401998 s 320 . I change my vacuum pump and now the doors just closed when I press on the remote control.when I pressed on open doors on the remote and the vacuum pomp still close it . I change the wires maybe the pomp work just for sucking and not for release. But still it is the same. I checked the lines to the doors and it’s ok .
Can some one tel me please if the pump should work like this, if not, what els?
​​​​​​​oren
Old Mar 15, 2018 | 06:07 AM
oldsinner111's Avatar
s320
did you pull fuses to doors in the trunk,to reset the pump?
