S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
S500 Hood on a s420?
Old Apr 22, 2018 | 05:03 PM
Tywilsxn's Avatar
95 s420
Just recently bought a 95 S420. It was in a small fender bender before I bought it so the hood was replaced but now the hood doesn't sit right. Apparently the hood that's on it now was taken from a s500. So my question is will this S500 Hood fit my s420 or do I need to buy a new hood?
Old Apr 23, 2018 | 06:31 AM
oldsinner111's Avatar
s320
is there a difference between swb and lwb? I heard s600 were different because of fitting a radiator.
Old Aug 20, 2020 | 10:58 AM
Kebowers47's Avatar
001 s600, 94 sl600
hoods different on S-600? length?
The '600' series S class IS DIFFERENT, being lengthened between windshield and front bumper to acommodate
longer engine and more accessories.
Old Aug 27, 2020 | 04:22 AM
syljua's Avatar
1998 C140 CL500
So in that, you say that a 600 bonnet, side fenders, etc. are longer?
Do you have any measurement for that?
Rgds the swb and lwb, here are measurements of W140 and V140, and the difference is purely 100mm extra on the back door area (height measurements will be dependent on how low the car sits on its wheels)
br,
syljua
Old Aug 28, 2020 | 05:05 AM
syljua's Avatar
1998 C140 CL500
Hood for S420 and S500 are the same part numbers;
1995 S420;
https://www.mboemparts.com/v-1995-me...and-components
1995 S500;
And since you do not say which year the S500 hood is from, this indicates that the partnr. are the same for all years;
https://www.mboemparts.com/oem-parts...bC12OC1nYXM%3D
What could be your case, is that you are trying to mix the non-charcoal filter hood 140 880 26 57 (without slats at the top), with a charcoal hood 140 880 24 57 (with slats).
br,
syljua
