Fuel Pressure In fuel rail.
I should also mention here that with the vacuum hose attached, it will only reduce the fuel rail pressure, momentarily in relation to the vacuum. Thus, at idle, strong vacuum, lower psi. But always "trying" to reach its (FR) set pressure. Yes, the fuel rail pressure thus varies, to the lower end and never over the set pressure of FR.Oldsinner111, thanks for the info. Anyone has this info from the manual, please chime in. Thank You!
