S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
96 S420 AC IS BLOWING HOT AIR,WHY???
Old 06-21-2018, 06:39 PM
steelers6nj's Avatar
1996 Mercedes-Benz S420
Hello I have a 96 S420 with over 200,000 miles and when I turn the AC on it's blowing hot air,now one independent Mercedes Benz shop tested it and told me it was my evaporator core and the job would be a staggering $3000,another thing what test is exactly done to tell that the evaporator core is really bad???Now I was also reading something about evaporator core sensors that can go bad,I'm wondering maybe it's as simple as replacing a bad sensor,what do you guys think??? Thanks in advance...
Old 06-21-2018, 10:58 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
We and you haven't seen the test results, so I am going to era on the conservative side and say your trunk is full of beer cans and the noise has affected your sanity----your car has AC self tests why not search the forum and do the fault test---then you can tell us?
Old 06-26-2018, 07:52 AM
oldsinner111's Avatar
s320
the evap's will leak,their are several good sealers.
Old 06-26-2018, 02:02 PM
Appreciate the feedback,would you happen to know the names of some of the sealants???
Old 06-27-2018, 06:28 AM
s320
supercool is one,about $12. make sure compressor is on,then fill wiping port good,then fill with freon.
Old 06-27-2018, 06:30 AM
s320
also unit in dash was made poorly,buttons don't always work,a rebuilt is $600. I just do without air.
Old 07-30-2018, 12:43 PM
Antonio s600's Avatar
W221 s550
Check to see if the AC damper (A31) is stuck. You can check by having someone turning your car ac on and off. You should hear clicking as is Turing from off to on. The clicking is the inside engaging. Next check to see if ( in this pic where the top arrow is pointing) is working or not. I had the same issues as you. I pulled the whole part out that the arrows are pointing too at a junk yard for $10. Took it home. Hooked it up to my Benz, and now my ac works.
Old 08-03-2018, 01:13 PM
Thanks I'll look into it...
Quick Reply: 96 S420 AC IS BLOWING HOT AIR,WHY???
