S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Soft-Close not working...
Old Aug 3, 2018 | 04:42 PM
bullrich's Avatar
2007 CLK63
1995 S320 SWB.
So...my door and trunk soft-close is not working. Further, when I use the IR key remote to unlock the doors, all but the drivers door unlock. However, when LOCKING the car, using the key or the IR remote, all doors lock.
I can hear the pump running under the rear seat, and have even inspected it, disconnected the power and reconnected it, and then tried the door/trunk close aid again, but to no avail. When seated in the car using the door lock/unlock switch, I can hear a hissing from the driver's door when pressing unlock. The driver door won't unlock except with the key.
And the soft-close still appears to be inop. Any ideas on what I might look at next?
Thanks! Brian
Old Aug 4, 2018 | 07:24 AM
oldsinner111's Avatar
s320
mine has fuses in the trunk,you can pull out to reset,should be 3 different ones,or just disconnect battery
