exposed elec circuit to battery charger
The battery was completely dead this morning so I removed the battery and connected the battery to the charger and it should take between 12 to 24 hours to fully charge. I will check at 12 hours.
I am worried that I did serious damage to the electrical system of the w140.
If I were able to get back to where I was before charging, I would pull the fuse for the soft close pump and move forward with a repair this week (go in and at lease look and listen to the pump operate). But now I have a bigger potential problem.
Tomorrow I install a fully charged battery and pray.
What else should I do?
Background on car. 1995 s500 w140 one owner car with 102k mi. I have had if for one year. It is reliable and mostly working well (until I zapped it.)
New question: I tried to lock the truck manually by using the proceedure in owners manual where I use the button inside the trunk lid and by pushing the lock device in. this did not work. no clicking no movement at all. I may be doing something wrong but it does not seem so. can anyone help. these truck mechanism seem to be ground zero on these cars. Thanks.
