Remove ADS shocks and replace with standard shocks
Is it possible to remove ADS shocks, and related hydraulics, ADS module and replace with standard shocks on a 1993 600SEL?
We never use ADS and prefer a softer ride.
Thanks!
Thanks for the input.
I plan on removing the shocks and replacing with Sachs on front and Bilstein on rear.
How do I disable the hydraulic pump on the rear self leveling?
I have already removed the ADS computer and ride on front is much better.
Thanks,
Helga
I have been told that removing the self leveling components will result in the vehicle sitting lower since there is no residual pressure. The front probably makes no difference since the shocks only contained valves that changed the dampening.
As to the ADS computer if it failed, the default is the firmest position for the daper valve units.
Any ideas if this is good idea or not?
JRBenz
Getting the right spring and pad partnr. involves gathering "points" for every
optional equipment you have, and select blue or red versions (I think
red and blue versions are the tolerances on stiffness-factor from production?)
Have a look at the footnotes in these part drawings (from EPC, which is the
same used by the part persons at Mercedes);
Front;
http://www.detali.ru/cat/oem_mb2.asp...SGR=052&SGN=01
Back;
Now, these are for the ADS S600. I guess that at least for the rear, you can
look at the calculations for a S500 without ADS at the rear since it's most difference
are the weight of the motor;
http://www.detali.ru/cat/oem_mb2.asp...SGR=120&SGN=03
Good Luck,
syljua
http://www.benzworld.org/forums/w140...-help-how.html
