S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Side mirror
Old Sep 16, 2019 | 05:32 PM
Salute's Avatar
1992 500sel
Side mirror
My driver side mirror stop working the motor for the side mirror is working it’s like it’s not catching
Old Oct 1, 2019 | 06:52 PM
demichae's Avatar
1999 ML430
When you touch the mirror glass does it move freely? If so, that means that the white plastic piece that's attached to the motor, and "pushes" the mirror glass in the direction you want it to go, is broken. You can get that motor at a junk yard, and 96-98 C or E Class sedans have the same motor. It should be less than $10.
It's not tough to install, but I think you have to remove the outer casing of the mirror housing. It's too hard to describe here, but with the mirror housing folded in, there's a thin metal rod that you need to pop up to slide the outer housing off. Once it's off, you unhook the little piece of metal wire holding the mirror glass, then pry the glass off of the motor housing. There are then three screws holding the motor. You just unplug it then plug the new one in. Be sure to attach the mirror, with the metal wire, BEFORE attaching the housing, as it's extremely difficult to reattach with the housing already on it. You can probably find a video on the Internet showing how to do this. If not, perhaps I can shoot one. I've rebuilt dozens of these mirrors.
