S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1997 S600 - engine cranks, but no ignite
Old 03-02-2020, 02:51 PM
Steen Staudal's Avatar
1997 S600 Black
I need help. Have fixed my S600 over the last few years and been driving it on our property. Unfortunately, I left it for more than a year and now the engine won't ignite. It cranks normally. I am not an expert on the engine, so I would much appreciate any advice about where I should focus my troubleshooting, please? Thanks for any advice that may give me some direction.
My 1997 S600 back in 2016.
Old 03-11-2020, 05:41 PM
Zacman1's Avatar
67 250sl
Lightbulb S600
You need to check for spark and fuel. the fuel pump is under the right rear, have someone crank The engine and feel if the pump is running or use a screw driver to your ear, it should buzz. Next check for spark, remove one of the front ignition wires, pull gentle and the connector will come off. remove the plug, stick it in the connector, put the plug theads to metal ground, crank and look fore spark.
See above
Old 03-11-2020, 06:38 PM
1997 S600 Black
S600
Thank you, Zacman1. I will definitely check this the coming weekend and let you know what I find.
Old 03-22-2020, 02:03 PM
1997 S600 Black
S600
Hi Zachman1: I finally got to try to check it out, but now the starter malfunctions. I will call a mechanic to get it rolling again. Thanks for your advice though.
Quick Reply: 1997 S600 - engine cranks, but no ignite
