S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
a/c vent lights
Old Aug 9, 2004 | 09:05 PM
danefx's Avatar
97 s500
Question a/c vent lights
The lights behind the wheels that control the center a/c vents have gone out. How many are there? and how do you get to them. Also, since all went out at the same time I suspect an electrical problem, like a short or fuse problem. all the other dash lights work though. Has anybody else seen this happen?
Old Sep 8, 2004 | 12:36 PM
BenzKid24's Avatar
a Few Nice cars.
Yes Man it happend to mine too,pretty easy its 2 bulbs i had to go the Park Place Mercedes in Dallas to get the bulbs and all you need to do is..
1-Open the glove compartment and @ the end of the WOOD trim that goes int othe glove compartment there is a black cover snap it off and unscrew the screw that holds the WOOD trim to the AC Vent,then snap it off then the AC Vent will have to clips on each side pull them up and it will allow the control part of the vetn to slide out and 2 grey looking nuts will the visble and that is your bulbs! very ez a 5 min job!
Old Sep 11, 2004 | 01:12 AM
danefx's Avatar
97 s500
thanks benzkid I will try that this weekend.
