S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
ABS Relay Overheating, Hot, Battery Drain
Old Jun 26, 2020 | 08:09 PM
dbmoylan's Avatar
Hello all. For a W140, might anyone have encountered an ABS relay that becomes hot when the ignition is off? This is the silver relay ontop the ABS pump for the 1993 Benz 300SE. Tried replacing ABS computer module, cleaning both sides of the ground wire, and replacing the relay to name a few things. No DTCs or CEL. I suspect a problem with a contact somewhere. Also, don't know if the ABS pump motor itself is bad causing some kind of grounding, but again no DTCs being generated. Also noticed a clicking that occurs when the ignition is off, but only on occasion. Side effect is draining battery at higher amp rate during downtime. Am not experiencing any sudden braking during driving either. Might the brake light switch at the brake pedal be possible problem, though brake lights are off when brake pedal not pressed (have multiple connections inside switch that might be shorting)? Thanks for any thoughts, especially on circuit connections that should be checked.
Old Oct 13, 2022 | 02:12 PM
Pyle85's Avatar
W140 W211
Clicking relay
Same problem here. Did you find the problem?
