S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Center HVAC Vacuum Lines
Old Aug 2, 2020 | 06:49 PM
nishboo's Avatar
W124, W126, W140, W220, W222, R129
I recently had an issue with a PSE Pump I purchased online. I removed it to send back under warranty. The problem is that the flaps for the AC are closed, and I am in Florida during the summer time. Is there any way to open the flaps manually, and if so, how? 1999 S500
Thank you in advance for any help.
Old Aug 2, 2020 | 07:52 PM
nishboo's Avatar
Originally Posted by Plutoe
Nope and are you sure its the PSE as it simply supplies the push or pull to the flap actuator---whats really wrong
100% sure. I believe the flaps were closed before I removed the pump.
