S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1992 600SEL A/C problem
Old Aug 4, 2020 | 09:30 PM
stuntflyr1's Avatar
1992 600 SEL & 1993 600SL
Unhappy 1992 600SEL A/C problem
The A/C compressor on my "92" 600SEL is short cycling. When to car is initially started, the compressor kicks on after about 5 seconds and only runs for about 5 seconds then shuts off for a few minutes and then short cycles again for another 5 seconds. This is absolutely NOT a refrigeration problem. The new compressor that I just installed (factory Denso btw.) is doing exactly like the one I replaced. I was misinformed that it was the speed sensor on the compressor! The freon was weighed in. The pressure switches are fine and I replaced the evaporator sensor just for giggles. I have no idea what the diagnostic codes mean when I put it into diagnostic mode on the climate control panel. They are as follows and are deg. F: 1=79, 2=85, 3=89, 4=89, 5=88, 6=90, 7=8, 8=8, 9=60, 10=79, 11=78, 12=81, 16=A
Any insight would be greatly appreciated!
Nobody local has a code reader either! Arrrggggg!
Old Aug 5, 2020 | 07:43 PM
stuntflyr1's Avatar
Problem solved! FYI.... It was the main control unit with the 4 fuses in the "coffin". Blowing ice cubes now baby!
