S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
1983 380sec bolt pattern?
Old Aug 21, 2004 | 08:47 PM
Babakvvs's Avatar
2003 E500
I need to know if I can put the rims from my 2003 e500 or my 2003 c240 on my 1983 380 sec.
Old Aug 22, 2004 | 03:09 AM
snik's Avatar
96 S500 Coupe
simple!
take off one rim from either car and put it on the other and see if it fits
Old Aug 22, 2004 | 11:15 AM
Karl's Avatar
All Mercedes, except the G-wagen and Sprinter, are 5 x 112mm bolt pattern.
All use 12mm bolts, except the 140, 215, 220, and ML bodies [they are 14mm]
Yes, you can swap the wheels. BUT watch out for the offset difference!
Offset is the ET number on the inside of the wheel. Try to keep it close to the original.
Model P.C.D. Offset C/Bore
All (except below) 5 x 112 35...42 66.5
SL models 5 x 112 18...25 66.5
A Class, Vito 5 x 112 45...50 66.5
Sprinter 5 x 130 45
Old Aug 22, 2004 | 04:06 PM
Babakvvs's Avatar
2003 E500
Thank you very much for your assistance...
Sprinter 5 x 130 45
Old Aug 22, 2004 | 04:07 PM
Babakvvs's Avatar
2003 E500
I was thinking the same thing, but I guess I am just too lazy. Thanks for your input.
Originally Posted by snik
simple!
