S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Soft door
Old Mar 21, 2021 | 03:51 PM
dhogue's Avatar
1998 S420
Soft door
My 1998 driver door close for two second then open, all other doors work fine. Need help.
Old Mar 5, 2026 | 08:27 PM
SUNILP's Avatar
2015 E250D
Most likely the closing vacuum actuator is bad due to a leak internally. New ones are around 350-400 dollars. Fronts are a pain to replace as you have to take the latch assy out of the door
